Removing ac compressor!
HI,
I took the car to the mechanic to install an AC clutch, he said we have to remove the Radiator or the fan to take out the AC compressor. but I dont want to touch the Radiator at all, since it took me 2 years to reach a point that there is no water leakage from the cooling circulations.
any way, my point is can he remove the AC compressor install the clutch and check it if it has any leakage and reinstall it without removing the radiator and the fans?
Thx
Thx
You do not say if its a v8 or v6 but I can tell you I personally replace mine in a V6 3800 and While it was a PIA and took multiple extensions, swivels and bloody knuckles to get to the bolts from under the car, the radiator and cooling system did not have to be broke open.
