-   93-02 General (https://camaroforums.com/forum/93-02-general-41/)
-   -   removal of gauge cluster? (https://camaroforums.com/forum/93-02-general-41/removal-gauge-cluster-65912/)
fuzz1313 Nov 5, 2011 02:45 PM
how do I remove my gauge cluster? Im stuck on after taking off the plastic covering. I have a 98 z28 camaro, thanks !
iLL95 Nov 5, 2011 03:24 PM
| Repair Guides | Instruments And Switches | Instrument Cluster | AutoZone.com
fuzz1313 Nov 5, 2011 05:41 PM
we have to take off the top panel? or can we go underneath?
iLL95 Nov 5, 2011 05:55 PM
I believe you can still have access to the bolts without removing the whole top panel, here is a write up that Chaotic94 made for a 93-96, it should be similar to a 98, it's for interior lights but the first thing he does is remove the gauge cluster. https://camaroforums.com/forum/4th-g...A%2A%2A-59143/
4th GenGuy May 11, 2019 09:16 AM
I removed the lower panel, then the column, then the bezel cover, cluster came out in a few minutes
