Rear Gears
Old 11-28-2009, 01:42 AM
chewybacca11's Avatar
Default Rear Gears
My repair book doesn't show how to replace the ring and pinion! What the heck? I looked online and I couldn't really find something that helps either.
Number one... If I buy from richmond gear does it come with installation instructions?
Number two... Is this a hard thing to do? I'm no mechanic but I def have a lot of experience with minor repairs.
Thanks
Old 11-30-2009, 10:18 PM
probly has a separate unit repair manual for it. they are very hard even for the most experianced mechanic. i learned in auto class some 35 yrs ago and thats the only time i did it. lol.
Old 11-30-2009, 11:46 PM
DarkKnight's Avatar
GTO Killer
LimeKnight
i hope you know the richmonds are outragiously loud... like annoying loud... theyre very strong and work well jsut loud
Old 12-01-2009, 06:28 PM
blackz87's Avatar
Changing the gear set in the rear diff is NOT for the average person. You can try, but your car is going to be a garage queen with no running gear.
Old 12-02-2009, 11:02 AM
DarkKnight's Avatar
GTO Killer
LimeKnight
maybe ur just mentally challenged .... i changed in 4 hours never having done it before,,, and i had my mechanic look at it when he did my axel shafts and said i did good so.....
Old 12-02-2009, 01:48 PM
Anyone can go and change out the gears. The problem is adjusting the proper mesh and bearing preload. If not done properly the gears will be annoyingly noisy, and in the worst case lead to premature failure, oil leaks, etc..
Old 12-02-2009, 02:00 PM
If your gears are "outragiously loud... like annoying loud", then they aren't set up correctly. Rearend gears make noise due to a bad mesh, wear, or no oil, not because of being a certain brand.
Old 12-02-2009, 05:08 PM
DarkKnight's Avatar
GTO Killer
LimeKnight
i have motive gear in mine,,, i just know 3 fbody kids around me have richmonds and theyre all loud.... its because of the material they use... every mechanic or specialty shop ive talked to said they notice a much louder sound from the richmonds
Old 12-02-2009, 05:26 PM
OK, there's noise and then there's noise. You made it sound like you have a nasty howl...or do you? Everybody has their own idea on how "bad" a noise is.
Old 12-02-2009, 05:55 PM
DarkKnight's Avatar
GTO Killer
LimeKnight
mines not loud at all but i have a biggin made by motive gear,,, my 3 buddys with fbodys have richmonds that are pretty damn loud in the car
Quick Reply: Rear Gears
