Rear end Price
How much does a complete rear end go on a 1998 Auto Camaro?
Depends on your area and if its an original V8 Limited slip or an open diff.
Car-Part.com--Used Auto Parts Market |
93-02 should fit, if you have traction control you will want a traction control rearend if not you will want a non traction control rearend. tc rearend has a sensor on each wheel non tc has one in the center section. call around to your local wrecking yards and see if you can get lucky, may find one for couple hundred. non posi/open rearend will go for about 200 if demand in your area is light.
Guess you don't need a rearended anymore since you're parting out the car.
Oh, well he never said he was asking cause he needs a rear. I guess he was asking to sell one.
