rear end differences
Old Apr 20, 2009 | 06:49 PM
350rs's Avatar
March 2008 ROTM
Default rear end differences
Is there any difference ( Other than gear ratio) in a rear from a V6 to say a SS or Z? Im looking at one from a V6 with disc brakes for 75 bucks that howells, but thats fine since i would be rebuilding it anyway. And yes i know its a good deal wider.
Old Apr 21, 2009 | 04:11 PM
350rs's Avatar
March 2008 ROTM
nobody? its from an 02 is that helps any
Old Apr 21, 2009 | 04:56 PM
evilkal's Avatar
Just depending on the year, you may have a Series 2 or Series 3 carrier.
The main difference is the type of rear end (it's an 02 you said so it's a Series 3 btw). Check the RPO codes for a G80 code. The G80 tells you that the rear end is a limited slip differential. If it doesn't have it, then it is an open rear end. You can also look for the GU code. It will either be GU4 GU5 or GU6. 3.08 3.23 and 3.42 gear ratios respectively.
Old Apr 22, 2009 | 01:12 AM
95slvrZ28's Avatar
GU4 is 2.73
Other than that and the carrier, depending on whether the car had TCS or not will determine whether or not the rear end has a place for a single rear wheel speed sensor, but I don't think that's going to matter for your application.
Old Apr 22, 2009 | 11:45 AM
evilkal's Avatar
GU4 is 3.08 I thought? Cuz my car couldn't have 2.73 gears xD
Old Apr 22, 2009 | 01:38 PM
GU2 is 273
Old Apr 22, 2009 | 01:41 PM
95slvrZ28's Avatar
Agh, I got my option codes mixed up, sorry about that.
MS69 YENKO/4-SPEED
Jan 19, 2015 10:51 AM
jbe123
May 31, 2007 02:34 PM
gmcguy
LS Series Tech
15
Jan 18, 2007 03:25 AM
GRIFF
Jan 16, 2007 12:03 AM
rburdge
Jan 11, 2007 03:02 AM
