rear end?????
Old 09-08-2008, 07:43 PM
gmman200's Avatar
Default rear end?????
i have a 94' lt1 camaro z28, what do i have for a read end.
thanks
Old 09-08-2008, 07:54 PM
02StanGT's Avatar
Default RE: rear end?????
Look on the end of your drivers door for a sticker with codes. Look for one that is GU# <- Insert number there.
Report back to us, and we will let you know...
Old 09-09-2008, 03:38 PM
Guest
Guest
Posts: n/a
http://www.fullthrottlev6.com/forums...body_specificj
Once you find then numbers that should tell you, along with some other random rpo codes.
Old 09-09-2008, 03:59 PM
gvmv's Avatar
ORIGINAL: 02StanGT
Should actually be in glove box. Look for a GU code, for example mine is GU5 3.23
Old 09-09-2008, 06:57 PM
95slvrZ28's Avatar
It will be on both the glove box and the door. I think it's easier to open my door than to remove all the crap from my glove box, but hey, maybe that's just me...
Old 09-09-2008, 07:55 PM
02StanGT's Avatar
ORIGINAL: 95slvrZ28
I agree 100% with you.
Old 09-10-2008, 02:58 PM
cbr600rx7's Avatar
LOL ok so i am not the only one that hinds every thing in the little box
Old 09-10-2008, 03:27 PM
gvmv's Avatar
ORIGINAL: 95slvrZ28
Did not know that since all the stickers are gone off my doors :P
Old 09-10-2008, 03:49 PM
gmman200's Avatar
inside my door are two stickers but dont have a GU code, and in my glove box all it says for a Gu code is GU6. in the glove box there are a lot more 3 symbol codes, but does anyone know a stock rear end for a 93-97 LT1 camaro??
Old 09-10-2008, 06:37 PM
gvmv's Avatar
ORIGINAL: gmman200
GU6 is 3.42
Don't understand your question, "stock rear end for 93-97 camaro"
As others have said it varies. Auto's normally had 3.23 and manuals 3.42 but certain years had certain options where you could get different gears.
Quick Reply: rear end?????
