-   93-02 General (https://camaroforums.com/forum/93-02-general-41/)
-   -   Rattling from steering? (https://camaroforums.com/forum/93-02-general-41/rattling-steering-76874/)
nouturn20 May 3, 2014 11:15 AM
First off my car is a 2000 Camaro SS 5.7l. My car has recently developed a rattle that I believe is from the steering system. The majority of the time when I start the car after it sits overnight I'll hear a rattle from under the hood. If I turn the steering wheel slightly while sitting there idle it'll stop for a second then start rattling again. Sometimes it's the opposite where it won't rattle while idling but it will as soon as I turn the steering wheel to one side. This rattle only seems to happen when the car has sat overnight when it's cold. Once I get going and it warms up it's ok. Is there a common issue in the steering that might cause this issue? Any ideas on where yo start would be greatly appreciated
craby May 3, 2014 08:09 PM
yep sounds like the pump is not happy and will fail soon. could unhook the belt and start it for a second to see if the noise is no longer there.
nouturn20 May 4, 2014 05:46 PM
The rattling has been present for about 2 years now. When it first started it would only rattle at idle for 2-3 seconds when I first started the car and would only do it once every 4-6 weeks. It started right after I replaced my fuel filter so I thought it was a loose fuel filter bracket. About a year ago I did have a power steering pressure line burst on me and before I realized it I had driven the car for about 3-5 miles with no fluid in the system. Sometimes the rattle would be accompanied by a squealing sound that sounded like the belt slipping so a few weeks ago I replaced the Serpentine Belt, Main drive Auto Tensioner and Main drive Idler pulley. Didn't seem to help any. Any recommendations on a replacement Power Steering pump?
craby May 4, 2014 07:37 PM
there all rebuilt now so its hit and miss, i went through 3 before i got one that has lasted. the relief valve seat is fail point and thats part of the main body, at least thats what i was told by the factory guy.
