ram air problem?
Old Jan 13, 2013 | 11:57 AM
wildcat123's Avatar
Default ram air problem?
Got a 95 lt1 with the ram air package, and noticed a little problem under the hood -
the hose was just laying down under the engine.. what is it and what does it do? How did it get riped?
Old Jan 13, 2013 | 01:26 PM
BasicConcepts's Avatar
Technical User
Looks to be some sort of breather hose, pull off the air box and follow the line (probably goes to a valve cover)
Old Jan 13, 2013 | 02:09 PM
That's the optispark vent hose. Get a plastic hose barb, then cut and splice the hose. Looks to have been rubbing on something....your hood perhaps. So I'd route it differently to drop it out of harms way.
Old Jan 13, 2013 | 04:27 PM
wildcat123's Avatar
took the filter piece off and its a mess down there.. There are all kinds of tubes, hoses, and pieces, im not going to monkey around with it lol
I got a bud who is the manager of a tire kingdom here with a 10 sec transam and ill just let him look at it, water pump is leaking on the optispark to and he knows how to bypass it aswell
Old Jan 13, 2013 | 09:53 PM
androzer's Avatar
what is the job of this hose? in my car it was by passed, not any more. but when u try to blow air or suck air its closed! maybe cause the car is off!?
Old Jan 13, 2013 | 10:03 PM
It causes air movement through the (1995-up) opti to help prevent condensation and the resulting corrosion inside.
The older non-vented style opti's were more problematic, and the later venting was a "fix".
The vented opti has two ports and hoses, one hooks to a manifold vacuum source, and this one on the intake tube.
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
Beest
Jun 27, 2010 02:42 AM
IZZY1967RS
Jun 15, 2008 11:11 PM
2lucke4u
Sep 1, 2006 09:55 PM
