-   93-02 General (https://camaroforums.com/forum/93-02-general-41/)
-   -   Rad fan not coming on (https://camaroforums.com/forum/93-02-general-41/rad-fan-not-coming-71822/)
djsquare1 Sep 26, 2012 09:52 PM
I bought the car with this issue. The rad fan wont come on, so the previous owner installed a fan switch. I have just been using that ever since I owned it.
I changed the CTS with no luck, I have yet to check the wiring and how they wired the switch.
What else should I be looking for?
AboveTheLogic Sep 27, 2012 01:15 AM
Have you checked the fan relay?
djsquare1 Sep 27, 2012 02:34 PM
Wiring looks fine. I couldn't find the splice so Ill have to keep looking. I will swap the relay after work and report back. Fuses are all okay. Thanks.
MKCoconuts Sep 27, 2012 02:59 PM
You do realize that the fans don't turn on until the coolant hits a certain temp? I'm wondering the PO didn't realize that and only thought they weren't coming on so he bypassed them.
djsquare1 Sep 27, 2012 08:27 PM
I know that but maybe the previous owner did not. I swapped the relay and went for a drive. Kept the fan switch off until the dash temp gauge rose to 220 so I turned the fan on because I didnt want it to overheat.
When does your fan usually turn on so I can get an idea?
AboveTheLogic Sep 27, 2012 10:30 PM
Don't the fans always turn on when the A/C is on? My A/C is empty at the moment or I'd test and report back.
MKCoconuts Sep 27, 2012 10:53 PM
Fans are supposed to kick on @ 226* and back off @ 221* There were two styles though, '93 and early '94s only one fan would come on at full speed unless additional cooling was needed then the second fan would kick on, both at full speed. In late '94, early '95 Primary and Secondary fans that operate at only one speed.
In late 1994 and into 1995, there was a change to low and high speed fans. When they kicked on both would operate at a low speed and if needed would switch to high speed.
PCM gets it's readings from the water pump sensor (not the drivers head sensor) and if that isn't reading properly, the fans will come on at the wrong time or not at all. However, the fans do come on while A/C is running as well as when the SES light is triggered, so you could try either of those.
djsquare1 Sep 28, 2012 12:31 PM
Thanks for the info, ill wait til it hits 230 and see what happens. I have the dual fans in my 98, I think there is a low and high speed.
My A/C is empty and does not work just FYI
Ill see what happens after work today after I get my water pump back on.
MKCoconuts Sep 28, 2012 01:01 PM
Even if the A/C doesn't work, if you try turning it on, it should still kick the fans on (assuming all wires are connected properly). You could set the SES light off with something simple like unplugging a rear O2 sensor or the MAF sensor for a minute or so to see if they kick on.
