Quick Answer?
Old Apr 23, 2012 | 05:11 PM
Camaroboi22's Avatar
Smile Quick Answer?
What is the size of a stock throttle body?
Old Apr 23, 2012 | 05:16 PM
androzer's Avatar
wait, for what year? and y u need that ?
Old Apr 23, 2012 | 05:20 PM
androzer's Avatar
Old Apr 23, 2012 | 05:39 PM
androzer's Avatar
have u ever heard about the TB bypass?
any one have any Idea to advise in case he is working with it?
Old Apr 23, 2012 | 08:49 PM
48mm is stock for lt1. bypass is doing away with the heater at the bottom of the tb that has coolant running through it. its intended to keep the tb from freezing up in cold wheather. you just unhook the hoses and couple them together using a piece of pipe.
Old Apr 23, 2012 | 10:06 PM
Thanks for the help.
Old Apr 24, 2012 | 07:45 AM
androzer's Avatar
the bypass is really effective? noticeable? I heard that it gives more 5 HP.
beside in 1994 the hoses of the bypass are coming one from the triple head hose and one from the place when u make the air goes out of the water system when u wana refill it.
beside once I went through hell to find that triple head hose and finally I costumed one by hand.
u did the bypass for u r car?
Old Apr 24, 2012 | 08:19 AM
yes i did do the bypass on mine, mostly because the tb is easier to take off without the hoses hooked to it. did not notice any difference in performance.
chewybacca11
Aug 31, 2010 04:06 PM
robmnrd
Feb 22, 2010 12:04 AM
BaByHuEy_05
Mar 18, 2008 06:14 PM
jhop16
Dec 27, 2006 03:59 PM
