-   93-02 General (https://camaroforums.com/forum/93-02-general-41/)
-   -   question (https://camaroforums.com/forum/93-02-general-41/question-22281/)
1994z28 Dec 15, 2007 10:24 PM
question
what is the difference between the 93-94 and a 95-97 opti spark distributor?
02StanGT Dec 15, 2007 11:00 PM
RE: question
==There are two slightly different versions of the Opti-Spark distributor manufactured by GM. The first design version was made between 1992 and 1994. Other than some small vent holes, the first design Opti-Spark had no provision for evacuating built-up moisture. Also, the caustic ozone gases created by the ignition process were also left inside the distributor with no vacuum removal. This design was replaced in 1995 with a vacuum-vented Opti-Spark (1994 B-Body cars received the updated Opti-Spark before the F-and Y-Body cars). Along with the new venting provision, the second design featured a redesigned cam drive and a different electrical connector.
This was in one of Pete's writeups.
