problem with remote unlock
Old Feb 11, 2009 | 10:58 AM
VanHalen's Avatar
Default problem with remote unlock
Was just wondering if anyone else has this problem. The remote unlock and lock will lock/unlock only every once in a while. I either have to stand and hit the button for a mintue, or lock the doors from the inside. Do I need a new remote(I think its the factory one), or is there some sensor thats malfunctioning?
Old Feb 11, 2009 | 11:21 AM
LT1RUNNER's Avatar
Check your battery. Low voltage can cause this.
Old Feb 11, 2009 | 11:59 PM
VanHalen's Avatar
That would make sense, as the battery is decently old and needing replaced. What voltage should the battery have off?
Old Feb 12, 2009 | 09:37 PM
Indy Mike's Avatar
Had a similar problem with mine. New battery in the key fob didn't help. Took the fob apart and found a ton of grime built up on the contacts over the years. Cleaned with a little alcohol on a rag and it has worked like new ever sense.
fuzz1313
LS Series Tech
Dec 7, 2011 09:08 AM
camaro_florida
Oct 28, 2009 11:27 PM
black95z28
Jul 14, 2009 05:31 PM
cgilbert23
Jun 9, 2009 07:34 AM
evilhaserrors
Aug 3, 2007 12:22 PM
