Problem with my 95 z28
Hey everyone, Just bought a 1995 chevy z28 convertable. My first camaro. This car rocks. Anyway i am having some issues. I am hoping you guys can help. Issue 1 when i bought the car the heater work great. Now the heater blower motor cuts in and out. I was told by a local mechanic that it sounds like a relay. I found a bunch of relays on this car were can i find it?
Issue 2. No big deal just like everything to work. The car has power door locks. Never worked. Any suggestions. On were to start for debugging this problem. Thanks again for any suggestions
the blower motor relay is in the under hood fuse box, its a black box on the driver side fenderwell. for the door locks check the fuse. its on the driver side of the dash, kinda by the door hinge. on the inside of the cover on both should be a diagram for which fuse is for what.
Issue 2: What do you mean by they don't work? Do they make a noise when you push the button? My power locks were ceased up when I got the car, you could tell they were getting power, but they would not unlock. The solution for me was to start using them. I spend several minutes just manually unlocking them and locking them until it got to the point that they would unlock if I held the button for a few seconds, then after a few months of regular use they are now perfectly functional.
Thanks guys for the reply. The question i have i found the relay box on the fender well under the hood there are like 5 or 6 relays on the box do you know which one is the blower relay? The power door locks doesnt do anything no noise nothing. Thanks again guys for helping me out with this
