power switches for windows and door lock
http://www.hawksthirdgenparts.com/switches_2.aspx or check ebay. A lot of people around here are parting out their 4th gens, you can check the for sale section and look around.
yeah i was looking today and found a pair for 58 bucks but there was still a day and a half on them. and i also found a guy in AR who i guess has a junk yard but says he has alot of camaro items 50 bucks for both sides.
also can i replace just the glass in the side mirror or do i have to replace the hole piece?
WHAT? if your referring to the switches no, no i dont have used ones i had none. and ii ended up getting a whole new mirror. thanks thow
i needed the switch and the trim. now i have the a set but my windows still wont come down, the manual not much help ether replaced the fuses. Is there a module i mite be missing?
get the volt tester out and see if you are putting out power to and from the switch. if u have power from the switch to the motor its either a bad wire or motor. there is a express modual somewhere. i think its under the dash on the door side of the glovebox. i have something on it in my attachments ill find it and be back.
