power steering hoses. which is which???
my car is leaking power steering fluid from one of the hoses. but i dont know if its the pressure line hose or the return hose that needs to be replaced. it goes from behind the PS pulley to the steering rack. the car is a 99 camaro 3.8L v6
I think item (8) would be the High pressure hose. The one that runs to the holding tank (10) is the return. Yes the pic is from a V8 so the hoses may look a little different. Where they go gives you which is which.
i'm leaking steering fluid too, same car, same resevoir, lines, etc. and i thought there were only two lines (stupid me). i think my high pressure line is what is leaking on my car. how hard is it to replace this? i know the parts are relatively inexpensive.
We tried it
started out building high HP 383 using large journal 327 motor
yes they made a few
used SCAT forged rotating
AFR race ready heads
4 bolt splayed caps
etc
had top notch speed shot do it all
cylinder cracked on Dyno first pull
bought a Dart SHP blick
heavier better blick
started all over
engine makes 560 HP
just about as much torgue
runs easy
idles
starts easy
pure pleasure to drive
have the 327 68 large journal block
sleeved
bored 40 over
its for sale
KT Engine Works in NC did all the work
top shelf sprint car motor builder
yes they made a few
4 bolt splayed caps
etc
started all over
engine makes 560 HP
runs easy
idles
starts easy
sleeved
bored 40 over
its for sale
