posi/lsd for my 2002 camaro ls1
Old 10-25-2008, 12:19 AM
elias_799's Avatar
Default posi/lsd for my 2002 camaro ls1
i have a 2002 camaro z28 with an automatic and my biggest problem is that i can not get any traction when i got to the drag strip. it is not because i have lots of power (my car is completly stock my best is 13.12) it is because only one wheel spins and the other one does nothing. so i was looking at some LSD's. i found one on ebay:
http://cgi.ebay.ca/1989-2002-Chevy-C...3286.m20.l1116
does eaton make good quality lsd's ?
will it fit my car with the stock rear end gear ? i do not want to change my rear gear ratios because the car is daily driven and it is already a hand full when it starts raining slightly.
what is the stock rear end gear on an automatic 02 camaro z28 ?
is there any decent speedshops in canada that will not charge me an arm and a leg for this ? ( performance improvments is overpriced !!!)
please help me out.
Old 10-25-2008, 12:23 AM
SpecterGT260's Avatar
Ninja Administrator
Default RE: posi/lsd for my 2002 camaro ls1
your ls1 already has an lsd (or should). if only 1 wheel is spinning something broke. but something tells me that its working if you were able to get a 13.1 stock.
Old 10-25-2008, 08:28 AM
ledzeprokon6's Avatar
i believe that LS1s come with posi trac
Old 10-25-2008, 11:55 AM
elias_799's Avatar
i do not think i got one. cause when i do a burnout to warm up my tires only one wheel spins.
maybe the previous owner changed it(blew it up and put a cheap one in there). i had my car on a hoist last weekend and when i turn one wheel the other one spins in the different direction. if i had an lsd both wheels should spin in the same direction.
anyway i got to change it. what are your recommendations for a new lsd ?
Old 10-25-2008, 02:58 PM
Ninja Administrator
if you have a 10 bolt, just go OEM.
but if youre going to do that, u will get between 1/4 and 1/2 the way to a whole new 12bolt rear. I would just get the 12bolt and be done with it
Old 10-25-2008, 06:41 PM
elias_799's Avatar
do i have a 10 blot ?
and what is the difference between a 10 bolt and 12 ?
how much does the oem lsd cost ?
these may be dumb questions and apologize. i do not know much about rear ends.
Old 10-25-2008, 07:42 PM
importmd's Avatar
all v8 4th gens have LSD, you can pick up a whole rear end for $150 bucks
Old 10-26-2008, 08:57 AM
Ninja Administrator
hes right, i didnt consider that.
if you go to ls1tech.com and get on their classifieds section you will find a cheap 10bolt pretty quick.
Old 10-26-2008, 07:35 PM
i thought that all of the late model v8s came with posi trac
Old 10-26-2008, 08:07 PM
importmd's Avatar
Quick Reply: posi/lsd for my 2002 camaro ls1
