PLEASE HELP tryn to replace rear bearings
Old 03-24-2008 | 08:47 PM
z28punkhed's Avatar
Default PLEASE HELP tryn to replace rear bearings
Ihave a 98 z28 with limited slipthe rear axlebearings went on me,I can't seem to get the rear axles outI removed the rear brake assembly and the rear end cover, i'm stumped. Idon't know if i'm suppose to remove the the c clamps? so heres were i'm stuck what to do from here help?
Old 03-24-2008 | 08:51 PM
libertyforall1776's Avatar
Default RE: PLEASE HELP tryn to replace rear bearings
There's a screw you have to loosen (won't come all the way out) and that will enable the c-clips to fall out as you rotate... Watch those spider gears -- albeit tricky to reinstall ;-)
The c-clips hold the axle shafts in.
Failed Devices
05-16-2010 02:22 PM
Als95Z28
09-21-2008 01:05 AM
v802chevy
08-25-2008 10:38 PM
07-01-2008 04:16 PM
qmracer
12-21-2007 02:37 PM
Quick Reply: PLEASE HELP tryn to replace rear bearings
