p0466, '02 3.8convertible
Old 03-15-2012 | 12:18 PM
saltflat's Avatar
Default p0446, '02 3.8 convertible
hi my ride, '02 3.8 convertible 56k, repaired L axle due to lack of heat treatment, now have p0446 code.shop wants $$ to drop tank. i saw a shop document for p0441 code by libertyforall1776. is it possible to get this info for p0446 in my vehicle? need to know location of purge solenoid, vapor canister, fuel pump, and flow sheet for p0446. thanks for any help
Old 03-16-2012 | 11:54 AM
found this. P0446 Evaporative Emission Control System Incorrect Purge Flow info on the newer 4th gen evap is not easy to find. far as i know canister is behind the rear driver side wheel. under a plastic cover. the vent valve should be back in that area as well.
Old 03-16-2012 | 12:12 PM
Old 03-17-2012 | 05:21 PM
saltflat's Avatar
thanks craby, those pictures show vent valve and vapor canister on gas tank. will attempt a trap door exposure from above when weather is better thanks again for the help
saltflat
11-30-2011 11:08 AM
