p0446
hi problem solvers, my 2002 camero convertible 3.8 l is throwing p0446 code . i replaced the gas cap with no improvement. code is a vent solenoid problem. the problem is the vent solenoid is located on top of the gas tank. i plan to access the solenoid with a cut out flap in the deck,a process i've used to replace the fuel sender.before a start cutting does anyone have a flow sheet for diagnosing this code ? thanks for any help.
Hope it helps...
Document ID# 794655
2002 Chevrolet Camaro
DTC P0446
System Description
This DTC tests the evaporative emission (EVAP) system for a restricted or blocked EVAP vent path. The control module commands the EVAP canister purge solenoid Open and the EVAP canister vent solenoid Closed. This allows vacuum to be applied to the EVAP system. Once a calibrated vacuum level has been reached, the control module commands the EVAP canister purge solenoid Closed and the EVAP canister vent solenoid Open. The control module monitors the fuel tank pressure (FTP) sensor for a decrease in vacuum. If the vacuum does not decrease to near 0 inches H2O in a calibrated time, this DTC sets.
The following table illustrates the relationship between the ON and OFF states, and the Open or Closed states of the EVAP canister purge and vent valves.
Control Module Command
EVAP Canister Purge Solenoid
EVAP Canister Vent Solenoid
ON
Open
Closed
OFF
Closed
Open
Conditions for Running the DTC
DTCs P0107, P0108, P0112, P0113, P0116, P0117, P0118, P0125, P0443, P0449, P0452, P0453, P1106, P1107, P1112, P1114, P1120, P1220, or P1221 are not set.
The ignition voltage is between 10-18 volts.
The barometric pressure (BARO) is more than 75 kPa.
The fuel level is between 15-85 percent.
The engine coolant temperature (ECT) is between 4-30°C (39-86°F).
The intake air temperature (IAT) is between 4-30°C (39-86°F).
The start-up ECT and IAT are within 9°C (16°F).
The vehicle speed sensor (VSS) is less than 121 km/h (75 mph).
Action Taken When the DTC Sets
The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
An intermittent condition could be caused by a damaged EVAP vent housing, a temporary blockage at the EVAP vent valve inlet or a pinched vent hose. A blockage in the vent system will also cause a poor fuel fill problem.
Test Description
The number below refers to the step number on the diagnostic table.
This test determines if the fuel tank pressure (FTP) sensor is functioning.
Step
Action
Value(s)
Yes
No
Schematic Reference: Evaporative Emissions (EVAP) Hose Routing Diagram
Did you perform the Diagnostic System Check - Engine Controls?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
Did DTC P0443, P0449, P0452, or P0453 set?
Go to Diagnostic Trouble Code (DTC) List
Go to Step 3
Inspect the evaporative emission (EVAP) system for the following conditions:
A damaged EVAP vent valve
A pinched EVAP fresh air vent hose
Did you find and correct the condition?
Go to Step 14
Go to Step 4
Disconnect the purge line from the EVAP purge valve.
Turn ON the ignition, with the engine OFF.
With a scan tool, observe the fuel tank pressure (FTP) parameter.
Does the scan tool indicate fuel tank pressure near the specified value?
0 in H2O
Go to Step 5
Go to Step 8
Important
Always zero the EVAP pressure and vacuum (in H2O) gauges on the J 41413 EVAP Pressure/Purge Diagnostic Station before proceeding with diagnosis.
Turn OFF the ignition.
Reconnect all previously disconnected hardware.
Install the J 41416 Fuel Tank Cap Adaptor.
Connect the J 41413 and the vehicle fuel fill cap to the J 41416 .
Command the EVAP canister vent valve ON with a scan tool.
Important
Do not exceed the specified value in this step. Exceeding the specified value may produce incorrect test results.
With the J 41413 , pressurize the EVAP system to the first specified value.
Rotate the EVAP pressure/purge diagnostic station rotary switch to the OFF/HOLD position.
Command the EVAP canister vent valve OFF with a scan tool.
Does the scan tool indicate fuel tank pressure FTP near the second specified value?
5 in H2O
0 in H2O
Go to Diagnostic Aids
Go to Step 6
Disconnect the EVAP canister vent hose from the EVAP canister vent valve.
Does the scan tool indicate that the fuel tank pressure is within the specified range?
-0.5 to +0.5 in H2O
Go to Step 10
Go to Step 7
Disconnect the EVAP vent hose from the EVAP canister.
Does the scan tool indicate FTP near the second specified value?
0 in H2O
Go to Step 13
Go to Step 11
With a scan tool, observe the FTP sensor voltage.
Is the FTP sensor voltage more than the specified value?
4.3 V
Go to DTC P0453
Go to Step 9
Test for poor connections at the harness connector of the FTP sensor. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 14
Go to Step 12
10
Replace the EVAP canister vent valve. Refer to Evaporative Emission (EVAP) Canister Vent Valve Replacement .
Did you complete the replacement?
Go to Step 14
11
Replace the EVAP canister. Refer to Evaporative Emission (EVAP) Canister Replacement .
Go to Step 14
12
Replace the FTP sensor. Refer to Fuel Tank Pressure Sensor Replacement .
Go to Step 14
13
Repair for a blockage in the EVAP vent hose.
Did you complete the repair?
Go to Step 14
14
Important
Pressurize the EVAP system to the specified value with the J 41413 .
Place the control **** on the J 41413 to the OFF/HOLD position.
Monitor the J 41413 pressure gage.
Command the EVAP canister vent valve OFF.
Does the EVAP system pressure decrease?
Go to Step 15
Go to Step 3
15
With a scan tool, observe the stored information, Capture Info.
Does the scan tool display any DTCs that you have not diagnosed?
System OK
Document ID# 794655
Document ID# 794655
DTC P0446
System Description
ON
Open
Closed
OFF
Closed
Open
Diagnostic Aids
Test Description
Step
Action
Value(s)
Yes
No
Go to Step 2
Go to Step 3
Go to Step 14
Go to Step 4
0 in H2O
Go to Step 5
Go to Step 8
Important
Important
5 in H2O
0 in H2O
Go to Step 6
-0.5 to +0.5 in H2O
Go to Step 10
Go to Step 7
0 in H2O
Go to Step 13
Go to Step 11
4.3 V
Go to DTC P0453
Go to Step 9
Go to Step 14
Go to Step 12
10
Go to Step 14
11
Go to Step 14
12
Go to Step 14
13
Go to Step 14
14
Important
Go to Step 15
Go to Step 3
15
System OK
Document ID# 794655
update ,cut deck to expose the vent valve and replaced it.code still present. checked voltage to vent valve 14 v.but the vent didnt close . when i grounded the valve it closed. so i guess the ground wire is the problem. does anyone have a schematic for a 2002 3.8 camaro convertible?
thanks craby for the schematic i found the ground wire for the vent solenoid c2 45. on the pcm. is there a pictorial diagram for the pcm plug.? the camero has two plugs to the pcm and i dont know how to locate c2 45 to check the ground. thanks again for the great help, the solution is near .
hi craby, traced the ground to the pcm it was ok.the problem is with the pcm, its not switching the ground on.this is our new hi tech systems malfouctions,spend $$$ to replace a pcm just so it can do a test which doesnt affect the cars function. thanks for all the help with dxing this problem
