Out of ideas..
Yea the fuel system has no problem holding pressure for a good while, the gas cap has a good seal and the mass air has been cleaned. I haven't check the egr or the O2s so that will be my next order of business
Is there no way it could be the security system? I and my mechanic have tried everything with no luck, he says there is a second security bypass, not the one at the key but one controlling the injectors? He's done testing with noid lights and says some injectors are not getting a ground connection on startup but all connections are good, and the pcm has been replaced. Im about ready to scrap this thing as I have almost $1000 into it and haven't gotten anywhere
i would take it to a different mechanic. someone that has a diganostic machine like a tech 1 that can see what the sensors are doing while the motor is running. i dont see how vats could do what you are seeing. heres some info on vats
4th Gen LT1 F-Body Tech-PassKey/VATS
4th Gen LT1 F-body Tech Articles
http://shbox.com/1/vats_bypass.jpg
https://camaroforums.com/forum/techn...-delete-63327/
https://camaroforums.com/forum/93-02...rt-vats-69934/
If its something electronic, it should set a trouble code. Thats the whole premise of having a computer thats capable of doing diagnosis. Id say its something mechanical. Have you driven the car with the fuel pressure gauge hooked up where you can see it?
2Z'sIf its something electronic, it should set a trouble code. Thats the whole premise of having a computer thats capable of doing diagnosis. Id say its something mechanical. Have you driven the car with the fuel pressure gauge hooked up where you can see it?
