Oil Presure droping?
little problem is that when i stop on a red light or a stop sometimes the the oil gauge starts moving from left to right just a bit and then the car starts to shake a little whats might be causeing that problem?
I think what you are seeing on the gage is a result of the shaking not causing it. Oil pressure drop the lower RPM it can drop real fast once your idle goes below 700 RPM. Fix your idle issue and I think your Oil pressure will be fine.
As to what is causing your shaking or bad idle there are a lot of things that can cause that. Bad gas, Leaking EGR valve, Tired IAC. Almost all your normal tune up stuff ect. |
Originally Posted by Gorn
(Post 459433)
change oil, new plugs, check plug wires and replace if lookin bad, check air filter and change if needed and scann for trouble codes.
| All times are GMT -5. The time now is 08:06 AM. |
