oil pressure problem plz help!
my oil pressure is low when im at idel it sits at about 20 an pops up and down!!! when i am on the gas it gos back up to around 40 and more.. has anyone had a prolem similar to mine??? need help asap
RE: oil pressure problem plz help!
It might not really be a problem, mine fluctuates a bit after the car is warm. You could try replacing the sending unit. It is behind the intake manifold, so you need to remove the intake but that's not a very big deal.
