oil pressure gauge?
![Wink](https://camaroforums.com/forum/images/icons/icon12.gif)
my oil pressure gauge is not working at all i dont know if the pump is bad or if its something much simpler... like the actual gauge lol. anyway, the "check gauges" light is on and i think its because the oil pressure gauge is not working but i dont wanna assume anything so i wanna fix the oil pressure gauge and see if the "check gauges" light is on. so my question is where do i start how do i check the oil pump without taking it off and i have the93 3.4 v6 if that matters. any info will be appreciated thanks to all
yup replace the oil pressure switch and it should be good
Oil Pressure Switch | 1993 Chevrolet Camaro 6 Cylinders S 3.4L SFI | AutoZone.com
You should check your computer for codes, I do not rememeber a code for oil pressure or oil pressure gage in the older Pre OBD1 systems. Infact I don't think the the gage is connected to the computer system. There is seperate oil sending unit that will cut fuel pressure if it reads zero so you most likely do not have "zero oil pressure" Not to mension that if you really had no oil pressure your valves would make a LOT of noise about it.
I don't get a check gauges light. My oil gauge just doesn't operate as it should. For example if I turn the car on, then turn it off. The gauge will stick at halfway, then if I cycle the key it will drop back down.
ok guys thanks for the input im going to buy it tomorrow. is this part something that MUST be brand new or can i get it at a junk yard? is it expensive?
also 1augapfel, is it the black "tube" looking pice by the blue filter? and luciora, dont worry you can "jack" the thread we are all here to help each other lol.
