Oil cooler 93 Lt1
Old Apr 5, 2014 | 03:30 PM
Default Oil cooler 93 Lt1
I got my Lt1 fired up and she is dumping oil around the oil cooler adapter. I found the GM number (14087586) for the seal but does anyone know if the is a aftermarket? I would like to get it running this weekend and deal is not open till Monday. I also may need the coolant seals also, this motor is out of a totaled car, the amount is leaking I would not be surprised if the adapter is cracked.
Old Apr 5, 2014 | 04:01 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Delete it. There's a few write ups online, they really have no benefit. A lot of lt1s came with it stock.
http://www.camaroz28.com/forums/lt1-...95-lt1-866582/
Old Apr 5, 2014 | 06:02 PM
I did not know about deleting them. I started researching. Seems the 93-95's are the good ones made by Moroso for GM. But I also read the even GM says with Synthetic oils the cooler is not needed. I am a Mobil one guy,, cleaning up two quarts off the floor was not fun ;(
Still not sure if I am going to fix it or delete is since the 93's are not one of the problem years.
Old Apr 5, 2014 | 06:27 PM
i deleted mine. not enough room with the bigger oil pan and headers. i relocated the filter up to the front by the air pump. i figured with more oil from the bigger pan and the hoses and stuff from the relocation it would be good. i also use m1
Old Apr 5, 2014 | 06:45 PM
What did you guys do about plugging the lines up? Did you us a pluming type fitting on the water pump? What did you do with the fitting on the radiator?
Old Apr 5, 2014 | 08:11 PM
i ran a hose from the radiator to the water pump. figured that circulation was needed or designed that way and didnt want to change flow.
Old Apr 6, 2014 | 12:36 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
This. Just get a piece of hose (can't remember the size) and run it from the pump to the radiator.
Old Apr 6, 2014 | 12:41 PM
Did you buy the adapter for the filter or just cut the existing one that holes on the cooler?
Old Apr 6, 2014 | 02:27 PM
if i remember right the cooler comes right off and you screw the filter on. don't need adapter.
Old Apr 6, 2014 | 02:37 PM
the pipe that the filter screws onto unscrews and oil cooler comes off.
