OBD1 Pin Jumping
Hey guys, I have an intermittent code on my 94 z28 that keeps popping up about once a week. I just tried to jump the pins but it wont go into diagnostic mode, I should also note that I have the low coolant light now and then as well. Has anybody else had luck jumping the two top right pins in the obd1 connector? It would be a very convienient way to pull codes without buying a scanner. Does the code has to be active in order for it to go into diagnostic mode? or should I be able to read stored codes anytime?
you can not flash for the codes on a 94. 93 was the last year.
Can you reccomend a good scanner for 94s? I tried one at Partsource and it wouldnt respond, I would like to get this code cleared up, I dont think its anything serious because the car has been running great but I hate looking at this ses light
have a look here https://camaroforums.com/forum/lt1-l...ks-94-a-71161/
I have a 94 K2500 and a 98 V6 Camaro and I wanted a code reader that would work on both cars. I purchased the Innova 3120b and I'm very happy with it. It cost from $142 to $200.
It reads OBDI and OBDII. |
| All times are GMT -5. The time now is 07:32 AM. |
