O2 Sensor problem
Old 09-23-2010, 07:44 AM
BRADLS1's Avatar
Question O2 Sensor problem
Engine light came on and said O2 sensors bad so changed all four,light still coming on back on but only when i come on to it.I have SLP exhaust,not sure what the problem is and we are all stumped!!
Old 09-23-2010, 09:32 AM
Did it say if it was the primary or secondary (post-cat) oxy sensors? If the error is showing a post-cat sensor, then the problem could be with a bad cat converter.
Btw, this post is in the wrong section, you want the 4th gen section.
Old 09-23-2010, 09:49 AM
need to scann it for codes and let us know what they are. if there are any mods around this needs to be moved. oh and what yr and model?
Old 09-23-2010, 10:26 AM
thanks for movin it arrow.
Old 09-23-2010, 11:18 AM
BRADLS1's Avatar
98 camaro z28 ls1 i will check the code #'S
Old 09-23-2010, 11:20 AM
BRADLS1's Avatar
what do y mean bye any mods around this have to be removed.
Old 09-23-2010, 11:22 AM
BRADLS1's Avatar
there are 4 of them that i changed on the exhaust itself.
Old 09-23-2010, 11:52 AM
BRADLS1's Avatar
Its the sensors on the exhaust itself not on the cats,thinking it may be a bad ground?
Old 09-23-2010, 12:04 PM
moved not removed
Old 09-23-2010, 12:07 PM
You have two oxy sensors before the cats, and two after the cats. The two after monitor the cats to make sure they're performing as they're supposed to. If not, it will trip a code and the check engine light will go on. Those two sensors don't alter engine runnability like the pre-cat ones will. That's why you need to see which error code you get, it will specify which sensor(s) it is.
Quick Reply: O2 Sensor problem
