No Spark on 1/4 coil
Old May 1, 2021 | 01:50 PM
BeardSteel's Avatar
Default No Spark on 1/4 coil
Hello out there, I'm out of ideas and need some help. At first I was getting spark on all plugs but number 4. Bought a new coil then got a spark every 5 seconds or so. Had already swapped the wire with a known good, switched coil to new spot it was fine. So I put in a new ignition control module, now I don't have spark on either 1 or 4 which would seem like a bad coil, but moved them to another spot and they work fine. It starts and runs, but it misfires. I tested the Cam shaft position sensor just to rule that out and it was fine, as were the wires from it to the ICM. Any help would be appreciated.
Steve
Old May 1, 2021 | 03:04 PM
Might want to post year and model engine size etc.
Old May 3, 2021 | 02:38 PM
BeardSteel's Avatar
Sorry, ya that would probably be helpful. It is a 2001 camaro 3.8 six cylinder.
Steve
Old May 3, 2021 | 08:17 PM
Steve
Well hang tight,some of the guys here know those 3800 motors well,I don't know a thing about them but have heard they are a good solid V-6 compared to the older ones.
Old May 5, 2021 | 10:31 PM
BeardSteel's Avatar
Thanks for the encouragement, but i think im going to have to take it in tomorrow. At 4 bucks a gallon i cant keep driving my car that only gets 14mpg to work everyday. But when i find out what is wrong with the car ill post it that way maybe it can help someone else.
Old May 6, 2021 | 11:13 AM
this sounds like the right call. will be easier to track issue with a good scanner. misfires can be a pain to deal with.
Old Apr 22, 2022 | 10:18 PM
Curt's Avatar
Default Same here
I have same problem almost except its 2 and 5 that won't fire right did u figure it out by chance?
Old Apr 25, 2022 | 10:16 AM
LastRS's Avatar
All 3 coils are the same (other than the numbers stamped on them).
Swithching positions will tell you if the coil is bad.
If the coils are good, I would look to the board they sit on as being the problem.
Old May 4, 2022 | 08:21 PM
BeardSteel's Avatar
Yes and no, I took it in they said the purge valve was leaking, They replaced the purge valve, it passed smog, Not sure how the purge valve affects that, but I got to spend $800. I think next time my car is acting up, I'll spend the $200 on the smoke machine and at least I'll have it.
Good luck.
dogdog130
Jul 12, 2011 09:49 AM
Dr. Evil
Aug 27, 2009 01:29 PM
big a
Mar 25, 2007 01:10 AM
camarocraz
Feb 19, 2007 12:21 AM
