No power
Old 08-14-2015 | 08:23 PM
Bonemaro's Avatar
Oh, well in that case, you're back at it with the cam sensor, which will cause the conditions you're getting as well as a no start condition. I'd have to check the book, but I'm sure there's a way to test the cam sensor to make sure it's bad.
Yeah I did already replace the camshaft position but still got the codes so I'm thinking its wiring or another piece of that system, maybe ICM?
Old 08-14-2015 | 09:42 PM
GaryDoug's Avatar
A defective or dead cam position sensor won't prevent the 98 3.8L engine from starting. The injectors will probably be out of sync, but the ignition is not affected because of the waste spark design.
Old 08-14-2015 | 11:32 PM
have you tested fuel pressure yet?
Old 08-14-2015 | 11:51 PM
Bonemaro's Avatar
No, I'm working outside and it was raining but more then that I wasn't able to buy a battery until late in the day (currently relying on other people for transportation, and hating it) tomorrow I should be fairly free though. I'll go to the local autozone and see if I can't rent one.
MaxTheKiing
08-23-2010 04:21 AM
rbeard
82-92 V8 Tech
08-09-2009 01:11 AM
dkblind87
LS Series Tech
07-27-2009 06:35 PM
IBADRIDE
07-13-2006 02:44 AM
