No A/C in dash vents :(
![Unhappy](https://camaroforums.com/forum/images/icons/icon9.gif)
When I turn the car on and turn the a/c on I feel it in my feet and feel it coming from the vent under the windshield but no air coming from the dash vents
It's the hot season and a little more A/C wouldn't hurt. I looked around and maybe it could be the vaccuum hoses?Actuator? needin some help
and if you know the problem posting pics or explaining where these hoses etc. are would be really helpful. Thanks ya have a good day
![Frown](https://camaroforums.com/forum/images/smilies/frown.gif)
![Big Grin](https://camaroforums.com/forum/images/smilies/biggrin.gif)
Follow this link, pretty sure it's exactly what you're looking for!
It usually is a vacuum problem, the actuators do not have enough vacuum to work properly and it only blows air out the floor and the vents up by the windshield(defrost). This article explains it pretty well. Should probably bookmark that site it's very useful.
4th Gen LT1 F-body Tech Articles
Pretty sure that is the line which carries the Freon. So yes I would assume that is your problem. Have you solved or figured this problem out yet?
**addition** I noticed you created another post on this issue, best to keep single threads on same or related issues and topics...my opinion anyways. But you might just need to buy another a/c hose assembly. Can get that for around $60 or so...
Yeah that was my bad :P Noone had responded to this post in 2 days so i made another post in the v6 section, someone had said that the air coming out isnt the cause of no a/c in the dash but the result from another problem. Idk im so confused at this point i just want a/c
