New TPS
Old 11-05-2008 | 09:17 PM
94z's Avatar
94z
Default New TPS
hey guys, after I put in my new 383 I had to adjust the tps (throttle positioning sensor) on it and ended up cracking it. The guy at the chevy dealer said he would get a aftermarket one for better throttle responce Im wondering if I should get a stock replacement for it or go aftermarket. The throttle responce on it now is not very lacking.
Old 11-05-2008 | 09:28 PM
02StanGT's Avatar
Default RE: New TPS
Don't see what the difference is. I have never heard of an aftermarket TPS.
Old 11-05-2008 | 10:54 PM
Saint_Ali's Avatar
Default RE: New TPS
yeah i just used a new stock one on my build, if it cracked you tightened it too tight
Old 11-05-2008 | 11:00 PM
02StanGT's Avatar
Default RE: New TPS
You are a damn genius Alih! I bet he was wondering why it cracked...
Old 11-06-2008 | 02:27 PM
94z's Avatar
94z
Default RE: New TPS
lol... I can see why you think it was from tightening but it was actually from me drilling too much of it out, had to make the holes in it bigger so i could adjust it for the 383
Old 11-06-2008 | 03:01 PM
02StanGT's Avatar
Default RE: New TPS
Are you using the same throttle body you had before? You shouldn't have to adjust the TPS because the engine changed. If you changed the TB I can understand. If you are needing to adjust idle, either tune it in the PCM or you can adjust the throttle stop screw. May be called the idle adjust screw also. It is the screwagainst which the throttle linkage sits when throttle is not being pressed.
