new o2's or im ok?
new o2's or im ok?
ok I have a 1997 Camaro Z28 6 speed
I just got hooked up with a used set of coated pacesetter headers for 150.00 they are setup for air/egr ( i live in California). I plan on buying the Percy seal for good gaskets, stage 8 bolts, o2 extensions(12"or 24" not sure)....but i have 2 questions because im piecing together this whole setup....
1. I live in California, will i need the ory pipe? because i did a clutch job 2 days ago and saw 1 o2 after the cat. So will i be able to use the ory or do i need to use the stock pipe or custom make?
2. I read that when the headers are new guys replaced front o2 because of the break in period causing ur old ones to foul out if u dont replace them. my question is because the headers i bought are used they have already been thru that break in phase will i still need to swap my o2's?
Any advice will be helpful especially if anybody thinks i am missing anything...parts, steps, etc. i plan on doin this job soon so any help would be nice thank you in advance.
