new to the forum
hello I am new to this forum I have 1995 z28 ,the engine is tired after 19 years or near,? my mech is installing a carberated 406 sbc crate motor from karl permormance . we got everything figured out pretty much with the mach up ,?WHAT IS NEEDED TO PROPERLY CONTROL THE TRANSMISSION SHIFT POINTS WHEN COVERTING TO CARBERATION. CAPS SO CLEARLY SEEN . ,some guys that have done anything similar may no ,the the lt1 is fuel injection ,an bang for my buck this seems the best idea ,any help would be great ,I am not certain how the forum works exactly yet I am thinking I am posting at the newbi point thank you
(Post 693714)
The transmission fix is simple you need a transmission for a 1993. It will have all the mounts you need and it is pre-computer control. |
well thank you for your reply ,not sure I understand I have an excisting tranmission ,in the 1995 ,so if I am understranding you then the transmission like some other thing will run off the excisting computer ,they just pulled the engine yesterday .so I guess what condufuseme is why I would need 1993 transmission .that would not be simple .couse I ahev fully functional car they are just swaping motors from fuel injection to carb thank you scott
93 is only partly electronic and shifts are controled by the vss and throttle cable. 95 is full electronic. the cost involved in doing what you wish will add up fast.
(Post 693720)
The PCM also control when your car shifts. You will need an older transmission from before they where controlled by PCMs. It really sounds to me like your mechanic is in over his head and has no idea the can of worms he has opened. |
i moved this portion of the thread to the 4th gen general section. the op in that thread has an 02 and 95camaro406 has a 95. i dont think a 95 has a bcm does it?
