New to boards '95 Camaro couple of issues
Old Jan 22, 2012 | 11:10 AM
  #21
MKCoconuts's Avatar
You could get a brand new aluminum drive shaft from summit for like $400 that's stronger than the stock one.
Drive shafts aren't too hard of an install. If you do decided to do it yourself, remember to replace the u joints.
Old Jan 22, 2012 | 12:55 PM
  #22
a one piece driveshaft from any 4th gen camaro will fit. have you checked the whecking yards in your area.
Old Jan 22, 2012 | 01:02 PM
  #23
What craby said, They only did that carrier bearing a few years. You can remove it and replace it with either a steel or aluminum one pc shaft (V6 or V8). The steel drive shafts osed normaly sell for $50-$60. The used aluminum one sell for about $100. Check Utube, the process to switch them is very easy the hardest part is jacking the car up. The only thing a Utube drive shaft video might not show you is unbolting the carrier itself, That is just 4 bolts that you are NOT gong to reinstall.
Old Jan 23, 2012 | 09:09 PM
  #24
pheonix782's Avatar
Haven't checked wrecking yards yet Craby. Doing that tomorrow.
Aluminum is better?
I honestly want to keep this car as long as possible and then some, so I'm ok with putting good parts in her. Or even putting in something used right now and then upgrading later on to possibly a V8 (apparently there's room for that under the hood) but that's a long way off.
Old Jan 24, 2012 | 12:18 PM
  #25
MKCoconuts's Avatar
There's room...just not much. Haha. But other than engines, suspension, wheels/tires, a V6 Camaro and a V8 Camaro are pretty much the same.
Old Jan 24, 2012 | 12:39 PM
  #26
not a good idea to switch a 4th gen v6 to v8. cheaper and easier to sell it and buy a z28
Old Jan 25, 2012 | 12:52 PM
  #27
305_camaro's Avatar
March 2012 Ride of the Month
Wouldn't you pretty much need a whole donor car to do this swap anyways?
Old Jan 25, 2012 | 08:15 PM
  #28
yes a wrecked z28 would do it. well so long as the k member is not damaged
ksink7
Jan 11, 2014 12:47 AM
bMoRe
10
Mar 29, 2012 10:46 PM
CP-Z28
Aug 22, 2011 03:37 PM
season07allday
Apr 13, 2007 06:18 PM
Fossil_160
Jan 19, 2006 05:20 PM
