Needs Help Identifying
Old Dec 19, 2010 | 10:45 AM
Mr._NeedHelp's Avatar
Question Needs Help Identifying
Hello all! I don't have a Camaro but I am working on one. I need help identifying a cap that looks like it goes over a hole where a distributor would be. 95' 3.4L
Thanks,
Jason
Old Dec 19, 2010 | 11:42 AM
osduck5's Avatar
Can you post up a pic?
Old Dec 19, 2010 | 12:09 PM
http://www.lunghd.com/Tech_Articles/...Project_XJ.htm
Not my pics but best I could find. Right column, 3rd down, and right behind the lower intake manifold.
Old Dec 19, 2010 | 12:24 PM
1augapfel's Avatar
That "cap" is the top of an aluminum housing that holds the oil pump driveshaft in place.
It is essentially the bottom half of a distributor, the housing holding a shaft with a gear at the bottom. The gear meshes with a gear cut into the camshaft and drives the oil pump. Think small block Chevy V8.
Here's a shot of the 3.4 out of my 94 Camaro. I haven't finished installing the oil pump drive in this pic because the new o-ring was missing from my gasket set.
Old Dec 20, 2010 | 09:30 AM
So what would the exact name of this part be when looking it up at advance auto? What happened was the person needed a new engine. I said I would R&R. Well when I got it out the place they got the new engine from said they needed the core before they would give the new. I didn't know what all would come on the new.
Old Dec 21, 2010 | 01:40 PM
1augapfel's Avatar
GM calls the pump the oil pump drive. It is AC Delco p/n 1104072 and that includes the o-ring. I assume that you will need the hold down clamp and bolt, too.
Where are you located? If you have trouble finding what you need I have a spare "parts" engine. I can pull the parts you need for a modest fee and ship them to you. I don't foresee ever needing another oil pump drive.
Old Jan 2, 2011 | 11:59 AM
I have the recon engine with a new pump and shaft but I don't have the cap thing. Where could I get one of those?
Camaroguy95447
Jul 7, 2015 10:17 PM
sstoeff
Mar 21, 2011 08:54 PM
mrted775
Mar 7, 2011 05:42 PM
PanamaJack
Jan 17, 2009 08:00 PM
