need some opinions
Old 12-22-2008 | 01:07 PM
outta_control_z28's Avatar
Default need some opinions
Well for the guys that were helping me before know that im buying a new opti lol , My next question is which one ??
I have msd wires so naturaly i went with a msd opti .. The msd is like 500 smackers so i looked around they have a accel one for 250 ? is the msd that much better ? or should i just run stock ? if the msd is the way to go then i will spend the bread for it , I like to give my sweetheart the best there is ya know ... I just dont like wasting money... thats a xtra 200 bucks that could go towrds my heads
Old 12-22-2008 | 02:03 PM
Saint_Ali's Avatar
Default RE: need some opinions
always remember you get what you pay for.The MSD unit is actually like $100 more than the GM replacement unit.It features copper points so you always get a better connection.It is also sealed better to keep out water,dirt,etc.Ive had mine on the car almost 2 years now with no issues.It is well worth it.
Old 12-22-2008 | 08:11 PM
Kevinz2895's Avatar
ACCEL makes good ignition products. You might want to go to the site and compare it to the MSD. If there similiar buy the ACCEL opti, thats my suggestion.
Old 12-22-2008 | 08:15 PM
torque_is_good's Avatar
I only have 2 weeks on the Summit optispark (supposed to be made by Accel). While it was all apart i did the opti, replaced all 8 plugs, installed 8.5mm wires, replaced the water pump and thermostat. I'm getting it ready to ultimately give to my son.
Now don't you know that one of the little hoses form the water pump to the radiotor has a little pin-hole leak. I only replaced the larger hoses...............I'm an idiot and should have doine the others too while it was completely drained.
Anyway, while doing the opti, check everything else since you'll be "in there"
Old 12-22-2008 | 08:27 PM
cbr600rx7's Avatar
I like MSD my self. Im not sure if you will get any extra juice out of it but i expect that it will be good quality and will last.
Old 12-24-2008 | 07:51 PM
95slvrZ28's Avatar
You're not going to get any extra power out of the MSD unit, maybe a little if you're modded and pushing your redline above ~6500 rpm or so. The MSD also has the capability of pushing the timing a little, but that's not really necessary since the PCM advances the timing as much as it can without detonation anyway. If I were to replace my Opti I would purchase the MSD unit because it's well made, and as Alih already brough up it's fully sealed and made with quality components.
Old 12-26-2008 | 12:32 PM
k guys thanks , Im gonna order the msd opti to match my msd wires ...I do like using the best parts out there and when it comes to the opti thing its a ***** to replace so i deffintly want the best one out there !!!!Thanks guys for all your help!!!
Old 12-26-2008 | 05:00 PM
z28rob18's Avatar
hey if you want look on herronperformance.com he has them for 515 instead of 560
Old 12-26-2008 | 09:04 PM
ORIGINAL: z28rob
Summit has it for $499 with free shipping.
http://store.summitracing.com/partdetail.asp?autofilter=1∂=MSD-8381&N=700+4294925143+400122+4294924761+115&am p;autoview=sku
ColinH
09-13-2012 09:43 PM
Gorn
09-04-2012 01:48 PM
z28rob18
12-31-2008 12:08 PM
Quick Reply: need some opinions
