need help with new clutch
anyways what car do you have??? basically all we know is that its a 93-02 manual we need a little info here
I think this is what he is trying to say.![Icon Emm](https://camaroforums.com/forum/images/smilies/icon_emm.gif)
And my kids wonder why they have to take grammar and English.![Icon Doh](https://camaroforums.com/forum/images/smilies/icon_doh.gif)
Try looking in the bellhousing to make sure the fork is properly positioned on the throwout bearing. Can you post any pictures of your clutch setup?
Did you torque the clutch to the flywheel properly? Did the clutch slide on the splines easily, before torquing down?
i put in the flywheel torq it down to spec then put the centering tool in . then after put the throwout bearing in the pressure plate and then put clutch on back and bolted up to flywheel. after i put bellhousing on with fork in throwout bearing. is there anything i missed
So what exactly is your symptom, the clutch pedal won't push in? Or when you push in the clutch the clutch doesn't engage? Does it feel like the pedal is entirely limp? Or does it feel like it won't push in at all?
