need help
Old 04-25-2012, 02:33 PM
tg2000's Avatar
Default need help
i own a 2000 base model and i want to change out the gear and diff. oil in it.i have also looked for aftermarket brake calipers fuel rails and an oil pan and sump valve thank you
Old 04-25-2012, 02:44 PM
Camambro's Avatar
April 2012 ROTM
was that a question?
Old 04-25-2012, 02:48 PM
Mikey.'s Avatar
I don't think so. lol
Old 04-25-2012, 03:38 PM
torque_is_good's Avatar
thank you
Even by spacing out what I think are the 2 sentences I can't make heads or tails of what you are trying to ask?
Old 04-25-2012, 03:59 PM
Since the thread title is "need help", my "big head" is telling me he must need help on doing the following (shown in bold) :
Old 04-25-2012, 05:50 PM
ahhh, you found my post ay?
Old 04-25-2012, 05:52 PM
ahhh, you didn't follow up on it yet ay?
Old 04-25-2012, 06:04 PM
sure nuff did (how do i get smileys?)
now to the OP here; when you say and gear and diff oil
do you mean manny tranny as well as diff or just the diff?
about brake calipers, it's a base and you're probabaly not road racing it on a circuit so stockers should be fine. What i always do is go to the rock auto web site, print out the price and go to adv auto and ask for a price match. if they won't come close, then i buy from rock.
At 12 years of age it's a good idea to flush the brake lines
Old 04-28-2012, 12:38 PM
tg2000's Avatar
all of what i said are questions i want to change the gear and diff fluids and i looked for the parts and got nowhere im trying to build a daily driven track car just looking for help and suggestions
Old 04-28-2012, 02:35 PM
jrollings's Avatar
Technical User
well to change the diff fluid, jack the rear of the car up and remove the bolts on your diff cover then remove the cover. clean off both mating surfaces then get a gasket or make a gasket for diff cover. Bolt diff cover back onto the diff and refill with fluid. (not sure on the appropriate weight though)
Tranny fluid ? auto or manual trans ? either drop the transmission pan or remove the drain plug for the transmission if it has one and refill with fresh fluid. You should probably flush your cooling system at this time too.
