motor/fram mounts
what engine is this?
you do need a new motor mount. that one is shot. so the mount bracket is busted? here is a link to a 4th gen parts manual. http://performanceworks1.com/PDF%20F...s%20Manual.pdf its a large file.
looks like its called an engine mount bracket..imma go to chevy dealer in the am, to see if i can order one and get the bolts for it....so you think i should replace the motor mounts as well?
and any good tips on replacing both these without removing the motor?
if its broke you wont find one at a dealer unless they have one in stock from a long time ago. search on ebabe for, camaro 3.8 engine bracket. found one for 15 bucks. you do know the mount is not bolted down right?
The only thing I see that could be taken as a breakin is that v-notch below the bolt. But it's supposed to look like that: 95 02 Camaro Firebird 3 8 3 8L V6 Engine Motor Cradle Mount LH L Driver Side | eBay
Hopefully you didn't get your hopes up too much. The $15 one is the passenger side, this one is $33. But still....is it really broken?
The only problem I see is that most of the motor mount bolts are missing. I don't see any at the bottom of the mount and the one at the top isn't even close to tight. That might be the whole problem.
I wanted to get new mounts for my 3.4 because the originals seem to transmit too much noise/vibration to the chassis at idle. Sadly, GM doesn't sell them anymore. I've had such poor luck with aftermarket mounts (made in India or China crap) that I decided to live with the old ones.
