Missfire at high RPM. Need help
Old Apr 25, 2012 | 06:24 PM
Erasto's Avatar
Exclamation Missfire at high RPM. Need help
I have a 97 camaro 3.8L and get code p0300 due to missfires on cylinders 2 and 5. I know its not the coil or ignition control module. It runs good and the code doesnt pop up till it hits 3800 rpm n up, it doesnt feel like its missfiring. Anyone have an idea of what it could be?
Old Apr 25, 2012 | 06:49 PM
How do you know its not the coil?
Old Apr 25, 2012 | 07:01 PM
Erasto's Avatar
They are new msd coils and i switched them around to see if the missfire moved to different cylinder but it didnt. I also changed the ignition control module and no change. I beleive it could be that its the spark plugs or wires that just happen to be under the same coil. Im planing on changing those out anyways.
Old Apr 25, 2012 | 07:24 PM
P0300 is a random misfire code, so how is it telling you that 2 and 5 are misfiring? Random misfire is usually the result of a lean fuel mixture; make sure the fuel pressure is holding when the engine is under load at high RPM when it needs the most fuel.
PO300 is a random/multiple cylinder misfire code. Do you mean you're getting a PO302 and 305? Plug wires and plugs would be the next logical thing to change. For fun, you could swap wires around and see if the code moves with them.
Old Apr 25, 2012 | 07:25 PM
^ Wow Pete.....that's creepy!!
Old Apr 25, 2012 | 08:31 PM
Erasto's Avatar
i have a scanner and it shows the missfires when i bring it up to 3800 rpm. the scanner also showing its having a good mixture, not running lean or rich.
Old Apr 25, 2012 | 08:34 PM
Erasto's Avatar
Its only showing p0300
Old Apr 25, 2012 | 08:57 PM
Then how did you determine you're getting a cylinder #2 and #5 misfire?
Old Apr 25, 2012 | 09:09 PM
Erasto's Avatar
I got a good scanner. Shows me everything the engine is doing.
