miss fire
Hello I'm new here would gratefully like some help here is the the problem my 95 Z28 starts to back fire at 4500 rpms got a hypertech programmer and moved the limit to 6500 and still get back firing new spark plug wires and I'm running ngk plugs in not sure about the optispark need help on what the problem is any advice would help thanks
I'm at a loss about what it is that you moved to 6500???
Anyway, more details are needed
example: all stock
egr/air deleted, long tube headers installed
aftermarket cam installed and now it has issues etc etc
Craby it's an engine swap I got the car on cl and the engine on cl to I just got it running it runs fine I just can't floor it cuz it starts to back fire at around 4500 and the spark plug wires are new got them on ebay not name brand some 10.4 mm $40 dollar ones
When you swapped the engine, what year is the engine and did you use the old ECU or the one from the "new" engine?
full disclosure is needed please. No nugget of info is too small
Backfire: popping out the intake.
Afterfire: popping out the exhaust.
Since the term backfire is often misused, which one do you have? There are different causes for each.
Afterfire........that's what I'm now going to call it. And about different causes, my wife swears that I don't need a reason and afterfire still happens.
I blame her cooking.
