misfire and pedal issues
Having an issue with both my acceleration and plugs. Just got all plugs replaced because of a resent misfire and still sounds like im getting on and on top of that my damn gas pedal won't either pressed down like it should or come back to its regular position im thinking the spark wires may be the issue why im still getting a misfire because i bought some cheap Autozone wires to put together and for the pedal im guessing the cord is the issue all advice is welcome
Originally Posted by 97RSClarice
(Post 707731)
if the pedal is toguh to push or won't come back, it's probably not the cable. Do the upside down on your back contortion and look for any obstructions at the pedal |
I was getting a misfire read in the scanner but ince i changed the plugs cleared it out and scanned again and nothing is coming up but still getting a misfire when i try to press down on the pedal
are you saying that you are constantly down a cylinder or is it more a random thing and clears itself up most of the time?
I think you have a six banger, right? I'm too lazy to see if it's a coil per cylinder or what. If it is, can you swap them around (again, unfamiliar with the six) if you can swap them, then do it and see if the problem moves. I'd also re-check all of my plugs and wires |
Yea imma check them out this weekend i just bought some more wires probably will change out the cylinders
And when i try to accelerate quick its like a kick back and takes off |
(Post 707756)
so it hesitates? have you checked the fuel pressure yet?
