Misfire in a few cylinders
I have a slight misfire in the 2500 rpm range. My android torque app shows 18 misfires current on cylinder 1, 5 on cylinder 3 and 5 on cylinder 5
Where do you think the Problem lies?
I'm thinking injectors possibly so I might switch them around to see if it moves to another cylinder.
Thanks
I have new plugs, wires and fuel filter.
Thanks
First you should check the spark with a spark tester on each of the cylinders. If you have bad spark you know the problem is before the plugs. Even if you have new plugs and wires. If you are getting good spark, then I would look in cleaning or replacing your injectors. If not, look at the coil packs.
What kind of gas do you run? It does make a difference were you get your gas. The injectors for a Chevy are smaller than a Ford. Where a Ford has a 8 mil injector, the Chevy is 5 mil. I think. Most gas is only filtered down to 6 mil. so injectors can get cloughed. The only stations that filter gas to 5 mil is Texico and Cheveron.
If you have good spark then it's after the plug wires that's for sure.
Do you run a K&N air filter? If you do, I'm sure you've heard about the throttle body sensor issue. Have you tested or looked at that sensor to see if it's working O.K.. It's easier to look at the wires to see if there black inside the sensor then to swap out injectors.
My point is if you are running the right gas, I can't see how your injectors are fouled.
I would swap coils first to see if the issue moves. It is easier to do and a much nore common issue. Most people run their plug wires to long and cause carbon tracking in the coil. It will spark test find until ther coil get hot.
Just curious, are you using the Torque Pro app or something else, and which bluetooth adapter? How do you like the app? Haven't used one, I use my laptop, but using the phone might come in more handy.
The torque app is a must have with the $15 bluetooth ebay adapter lm301 or something. It has more options than most $300 scanners. Get it! So many cool things you can do with it.
