Fuel Pressure
Fuel Pressure
I put a fuel pressure gauge on the schrader valve, and it read ~15psi at idle, I put it on another car and it read around 40psi so I know the gauge is fine, but my question is would this be a bad fuel pump, or something else? The car holds pressure after its shut off. Its an LT1 by the way.
RE: Fuel Pressure
hey,
to check if you have a bad fuel pump or not, connect the guage to the valve , then swtich ignition on but dont crank the engine. it should be between 40 and 45 psi,get someone to do that while you are at the guage,when the car starts it wil drop as pressure will be lost to injectors.
RE: Fuel Pressure
[align=left]
FUEL PUMP & PRESSURE REGULATOR TEST:
1) Connect a Fuel Injection pressure gauge (available from most part stores) to the test port on the FI rail (similiar to a tire valve). Be carful as fuel under pressure may spray out.
2) With the key ON & engine OFF (cycle the key ON-OFF several times as pump only runs for 2 seconds) the pressure should be 41-47 PSI. (If NOT: weak pump, dead pump, or no power to pump)
3) Turn key OFF, pressure should NOT drop more than 1-2 PSI and then hold steady. (If NOT: fuel line leak, injector leak, regulator leak, fuel pump check ball leaking)
4) Let engine idle, pressure should drop 3-10 PSI from the reading in step 2. ( If NOT: bad pressure regulator, vacuum leak to pressure regulator.
5) WOT (car accelerating at full throttle, pressure should hold @ 41-47 PSI. Good to have two people, one to drive and one to watch gauge (If NOT: dirty fuel filter, weak pump, bad pressure regulator)
[/align]
[/align]
royco95
08-02-2015 10:25 AM
BoricuaHec01
LS Series Tech
03-17-2011 05:56 PM
