LT1 Cam specs
im gona be building a new 350 for my car. Heard the LT1 cam is a good cam for the job. Do any of you happen to know the specs on the cam? i need it all, or just little pieces parts. thanks
RE: LT1 Cam specs
The LT1 cam is actually pretty mild. If you want to go with a GM cam I'd steer your towards the LT4 hotcam kit(it cones with the cam, valve springs, 1.6 roller rockers etc.), but you'll end up spending more money because it has "GM" stamped on the side. I'd go for a good custom grind to fit your heads etc. Choosing a cam isn't an easy thing to do, it has to be matched up to the motor to make a good power curve.
RE: LT1 Cam specs
ah, oh well. i saw one on craigslist for 25 bucks, so if it was worth it i woulda done it
| All times are GMT -5. The time now is 04:09 AM. |
