LT1 Cam specs
Old Nov 5, 2007 | 09:03 PM
350rs's Avatar
March 2008 ROTM
Default LT1 Cam specs
im gona be building a new 350 for my car. Heard the LT1 cam is a good cam for the job. Do any of you happen to know the specs on the cam? i need it all, or just little pieces parts. thanks
Old Nov 6, 2007 | 12:08 AM
95slvrZ28's Avatar
Default RE: LT1 Cam specs
The LT1 cam is actually pretty mild. If you want to go with a GM cam I'd steer your towards the LT4 hotcam kit(it cones with the cam, valve springs, 1.6 roller rockers etc.), but you'll end up spending more money because it has "GM" stamped on the side. I'd go for a good custom grind to fit your heads etc. Choosing a cam isn't an easy thing to do, it has to be matched up to the motor to make a good power curve.
Old Nov 6, 2007 | 05:17 PM
350rs's Avatar
March 2008 ROTM
ah, oh well. i saw one on craigslist for 25 bucks, so if it was worth it i woulda done it
Lopez_SS
Feb 10, 2008 10:08 PM
motor tec
Oct 16, 2006 10:38 PM
Toronto_Ben
Sep 22, 2006 07:48 PM
GRIFF
Sep 3, 2006 05:09 PM
1StockRS
Dec 8, 2005 10:42 PM
