a lot of smoke
i was racing today and wen i stopped i had a lot of smoke coming out my tail pipes my friend said it was an oil leak if it is how can i find where its coming from and fix it
it white like if i where to burn out it looks like the same smoke...im not exactly sure if its coming out of the pipes or off of them but i think its off of them cuz i saw it in front of me and to the sides not just the back
White smoke is usually indicative of a bad head gasket, not an oil leak. If it's an oil leak the smoke is going to be more of a blue color and will usually occur only when the motor is under a load.
so if its doing it only when u are running the car hard? if u think its leaking get under the car and see if u have oil coming from the motor or rearend. look the exhaust over for sighns of oil on it. we have had one person on here with a bad rearend seal that did somthin similar. also my intake manifold was doing somthing like that and it was leaking all the way around. it leaked at the front and back of the intake and made it look like front and rear seals were bad but following the trail i could see the oil was coming from further up on the motor. the intake gaskets (sides of intake) were also leaking bad so when i ran it hard it would suck oil into the cylinders making the exhaust smoke a little (not like what u have) but not when just crusin.
