Lookin into the whole LT4 thing
Old Mar 10, 2008 | 08:02 PM
  #31
95slvrZ28's Avatar
Default RE: Lookin into the whole LT4 thing
Whammer, you've almost got it. The LT1 has a different block from a "traditional" 1st gen SBC(thus why Chevy called it the "Gen II"). They're based on the same design, but the LT1 block has different mounting locations for the distributor and water pump.
Old Mar 11, 2008 | 03:01 AM
  #32
Spartan66's Avatar
ah i thought you ment have em rebuild my engine. What your saying is while the new engine is available have the heads ported etc?
Old Mar 11, 2008 | 04:50 PM
  #33
whammer3024's Avatar
ROTM Winner
i assumed he meant he was going to get another lt1 block so that's what i thought you were saying slvr. and yes spartan...i'm saying if you get another lt1 block then have lloyd elliot port the heads and match a cam to it. www.eportworks.com
Old Mar 11, 2008 | 05:11 PM
  #34
Spartan66's Avatar
baller. ok thanks for the tip
Old Mar 11, 2008 | 05:13 PM
  #35
73camaroSS's Avatar
Yearone has thecomplete kit i think. it has the headswith LT1rocker studs,LT4 intake,heavy duty single-roller timing set,GM hot camkit (camshaft.1.6 roller rockers,springs, retainers) all necessary gaskets and seals
$2,785.00kit
if you have a yearone book its on page 74
hope i helped you if not i tried, good luck with the conversion
Old Mar 11, 2008 | 05:15 PM
  #36
73camaroSS's Avatar
OH and i forgot its 450hp conversion
Old Mar 11, 2008 | 05:59 PM
  #37
95slvrZ28's Avatar
[sm=sigh.gif]
We already went over that the LT4 convesion is pretty expensive for the power that you get out of it. The advertised "450" HP that conversion gets you is just slightly over the 330 that was advertised by GM because they get the "450" on a dyno with the motor not running any periferals (no water pump, alternator etc.) and running a set of dyno headers. Once you get that "450" HP motor under a hood, running periferals and a full exhaust it's going to drop around 50-70+ crank HP. The only benefit of that kit over an actual LT4 is a slightly more aggressive cam.
Old Mar 11, 2008 | 08:23 PM
  #38
73camaroSS's Avatar
sorry for telling you something you already new,i tried
Old Mar 11, 2008 | 08:31 PM
  #39
SpecterGT260's Avatar
Ninja Administrator
A for effort
Old Mar 11, 2008 | 08:55 PM
  #40
95slvrZ28's Avatar
ORIGINAL: 73camaroSS
Sorry, I'm not trying to be a Debby Downer or anything, but the fact that it's already been discussed in this thread (page 2 or so)...and Spartan has already decided not to go with the LT4 package. I guess I just kinda get annoyed when people post up stuff that's already been discussed. Ok, now that we're all friends again...
