Lights Won't Work
Have you checked the bulbs? I know it sounds stupid but it could save you hours of hunting if you know they are good before you start tearing the car apart. Also did you have to unplug the fog light switch to get to what you needed to when you replaced the other switch?
Massey
Massey
And yes I did unplug the fog light switch.
I'm having a problem with just about all the lights. My low beams do not work, high beams at least do. Fog lights do not work. Lights on rear view mirror won't turn off unless I have the switch to sit in the middle. And the dome light wouldn't go out so I just took the bulb out.
pojo1988
08-27-2017 09:35 PM
