Lights Won't Work
Lights Won't Work
What can cause my headlights, foglights, and turn signals not to come on? The brake lights work fine and when I turn the lights on and turn the right signal on, the right brake light goes out. Same thing happens for the left. All the fuses are fine.
try moving the tilt wheel up or down and see if that effects anything. ive read of guys having issues with the wiring in the column that reacted when they moved the tilt wheel.
Just tried it, nothing happened.
Yes, I got the headlights and signals to work. I forgot to plug in the wires.
I'm just having trouble with the fogs. I tried looking for the wires but everythings so tight I can't hardly see them.
check this out
http://www.bfranker.badz28.com/fbody/fogs.htm
The fog lights were working fine until I changed a switch to the ignition thats mounted on the steering column. Are there any wires under there that are somehow connected to the fog lights? Could something be wrong where the switch to the lights are?
Have you checked the bulbs? I know it sounds stupid but it could save you hours of hunting if you know they are good before you start tearing the car apart. Also did you have to unplug the fog light switch to get to what you needed to when you replaced the other switch?
Massey
Massey
