The light for the window switches?
Old Aug 13, 2010 | 06:34 PM
Barkat's Avatar
Default The light for the window switches?
This is the little bitty light that goes right over the power window switches. Anybody know the part number?
Old Aug 13, 2010 | 06:45 PM
DarlingReject's Avatar
Prettiest Sixer Around
September 2010 ROTM
For the bulb? I think it's a 37, but I could be wrong. But I wasn't able to find an exact number for it after doing a quick search. I know it's itty bitty and looks the same as the one for the auto trans indicator. I've replaced that one and it was a 37. Both of my door lights are burned out, but I couldn't manage to get the bulbs out. They're so tiny and I was afraid of breaking it.
Old Aug 13, 2010 | 06:59 PM
Barkat's Avatar
Ya, I'm kinda scared of that myself! I just had the door apart fixing my speaker and thought I might as well fix the bulb too.
Old Aug 13, 2010 | 07:02 PM
September 2010 ROTM
I had a really hard time just with the indicator. I tried for awhile with the door and just gave up. The bulbs pull right out, but they're just so tiny and in there very tightly, so I just said screw it. I added pink LEDs in the door instead, haha.
Old Aug 13, 2010 | 07:09 PM
Barkat's Avatar
I dont think i will be going with the pink led route!
Old Aug 13, 2010 | 07:11 PM
September 2010 ROTM
Lol I wouldn't expect so. Just an idea though...haha. But if you do end up changing the bulbs, good luck! And try not to break anything.
Old Aug 13, 2010 | 07:18 PM
Barkat's Avatar
The only thing I am really worried about is the bulb breaking and slicing my fingers open. With a bulb that small it has to have real thin glass. Willing to bet that will slice real nice!
Old Aug 13, 2010 | 07:27 PM
September 2010 ROTM
Yeah, that would really not be the most fun time. Maybe try to wear some thin gloves when you do it? It's hard though because you have to get such a firm grip on the bulb. And they're just so damn tiny. I tried using like one of those rubber can opener pads and part of a drawer mat that is really grippy, but I still couldn't get enough grip on it. Maybe you'd have better luck than I did using something like that to help.
Old Aug 13, 2010 | 11:53 PM
Massey's Avatar
use a pair of needle nosed pliers and break the glass, pull on the electrodes inside the bulb and it will come out just fine. That is how I remove mine. And Darling is correct the bulbs are #37.
Massey
Old Aug 14, 2010 | 02:22 AM
September 2010 ROTM
Wow, I was actually right about something. Imagine that. I'm assuming it only took a few minutes to change them?
